Need some help. Long story short put new Polk speakers in my 07 RSV with a lot of help from this site. much improved over stock speakers. Then went to put in amp and screwed up and got a wire mixed up that was hot all the time to one of the speakers (my own stupid mistake, always check and double check). Blew the fuse for the audio. Put all the wires back to stock hookup and changed fuse but now remote controller on handlebar will not turn on. Don't know if it is the remote or the radio head unit. Pinwall has radio for $189 but no remotes. Can find new remotes but they are over $600. How do I figure out weather it is the head unit or the remote that is bad or both.
Any and all help appreciated.
remove positive battery cable for several minutes and see if it will reset.
also check left battery side cover main fuse box front most fuse,its marked "back up", and is 10 amp
Thanks, will probably be this weekend before I can get to it. Will let you know if this works.
So you do like the polk speakers way better than the stock? Do you get a little more low end from them? I know you wont get a ton because of the size, a little more would be nice.
Thanks
Adam
