rbig1 Posted October 11, 2015 #1 Posted October 11, 2015 I have a 01 venture. First question is, are there two pick-ups for firing ignition. Second question how and where do you test. The reason I ask is number 1 and number 3 are not firing. I cleaned and replaced coils cleaned plug cap they were both not working. Checked to see if I had twelve volts to rear coil. The ground on the coil bracket was broke off. So the coils test out good now have power going to them. going to look in manual at wire pics. It don't tell which wire goes into which plug at the igniter.
rbig1 Posted October 11, 2015 Author #3 Posted October 11, 2015 (edited) Ok I think these are the connectors. If they are the black one has no reading anymore. The white one is in upper spec. Any one confirm I'm correct? And this is a picture of bottom of coils wires on correct? I hope I'm correct but you never know till you ask. Hands shake so bad had a rough time with pictures. I want to thank you @dingy for the good wiring info the Clymers manual don't show ohms and connector colors that I could find Edited October 11, 2015 by rbig1 add thanks
rbig1 Posted October 12, 2015 Author #4 Posted October 12, 2015 I tested out the wires from the computer for the pickup and to the coils. All was good so ordered a new computer. Thanks for all the help.
