Does anyone make a replacement saddlebag for the venture / rstd that is maybe 3" wider on each side for a little more space? If no, has anyone purchased two used bags, cut out a center section then plastic welded it into the center of their bags / lid? I really like the look of the BeetleBags, but I don't see an application for the tour deluxe / venture. Thoughts?
could add a trailer hitch and put another trunk or box on when more space is needed and remove when not.
I have done both and they work just fine for what I need. I use a trailer when I need to, or just slip the extra trunk on when I need it
  • 2 weeks later...
