Just like the title says, I am looking for a used and abused 1st gen, MKII if it makes a difference, windshield. It does not have to be pretty at all. As long as the mounting area, and most of the outside shape is there. Major scratches or cloudiness from chemicals don't matter.
I will be sending it to Don at F4 windshields so that he can use it as a pattern to be able to make F4 windshields for the 1st gens.
After talking to Don this morning he said that if he had a pattern to design something, he would make the shields. He said that he would most likely not stock them but would make them on an as needed basis with about a 2 week lead time. I can deal with that.
I had my original stored away for a couple of years while trying to talk Don into doing the 1st gens. Just after I finally gave it away to someone that needed one, Don decided to go ahead and look into the 1st gen shields.:bang head::bang head::bang head:
I no longer have an OEM. I changed my OEM out to a Slipstream a few years ago cuz F4 did not make a 1st gen. I held on to the old one for a few years hoping F4 would change their mind, until a VRO member had one a lot worse than my old one so I gave away my old one I was saving. Now a few more years down the road F4 is looking for an OEM 1st gen shield to get dimensions off of.
I do have a "spare" and the F4 sure sounds like a nice shield.
But shipping from Canada would be horribly prohibitive, it's doubtful I could afford a new F4 and I also need my spare to make a power articulated shield this winter.
So I'm not a likely donor.
It is great to see some support for the old rigs though.
And, my post is a free bump for someone else to hopefully see the thread....:)
I've got one that is so yellow you cannot see through it. It does have a hole cut into the lower center because I used it for practice before cutting up my good windshield to install a GoldWing vent. Let me know if this will do the trick.
I believe that will do the trick.:thumbsup:
How did the vent hole turn out? Was it in the right location? That would only make it easier for F4 to add the wing vent.
It's been awhile since I cut it up, but I believe the one in the "template" was fine. He can try and fit one in and see......
[ATTACH]101817[/ATTACH][ATTACH]101817[/ATTACH]
Don't know if it's what you're looking for or if you still need on, but I also had this from my 88 VR I changed out this spring. Hope the image came through. It says it's Lexan and has a GE stamp in it. Don't know if it's the original for sure but it still has the rubber gasket along the bottom too.
The description on the shield reads:
AS6 M-121
GE
Lexan RMR Sheet
DOT 94
Getting one to Don is in process. It will be a few days for it to get there.
The item I received yesterday I hoped would have a large enough box was shipped to me with a label on the item and no box. Which brings up this question:
Can I just walk this thing into a FedEx store and have them label it, or do I need to find a box?
I guess you would have to call FedEX and ask. You may have to at least wrap it in bubble wrap or something.
OR, its only a couple hundred miles, might be a nice time of year for a road trip...........:Venture:
I was just down there a couple weeks ago picking up a tractor. Too bad I didn't know......
