bongobobny Posted April 5, 2008 Posted April 5, 2008 Looks pretty good and if that is the true mileage it ould be a heck of a deal. Clutch problem could be the master cyl or slave cyl. Only a short time left... http://cgi.ebay.com/ebaymotors/Yamaha-Venture-1984-Yamaha-Venture-NO-RESERVE-03-136_W0QQcmdZViewItemQQcategoryZ6718QQihZ013QQitemZ230238626987QQrdZ1QQsspagenameZWDVW
Squeeze Posted April 5, 2008 Posted April 5, 2008 I'm suspect on this Bike. They say it a 1300cc, but the Year says 1984(1200cc). The VIN appears as a 1984 Number with upcoming 2nd Gear Issue in Question. Other than this, it looks!!! fine. Oh and Motor running but no Advance, is definitely not a Clutch Master or Slave Problem. Maybe they didn't try to shift into a Gear ? Cheapest Malfunction might be the Star Washer is done or the Clutch Plates are completely gone. Might be ...
Lone Eagle Posted April 5, 2008 Posted April 5, 2008 Don't look, you don't need another bike .... :rotf::rotf:
BuddyRich Posted April 5, 2008 Posted April 5, 2008 :rotf::rotf: Watch, He won't be able to resist...
Venturous Randy Posted April 5, 2008 Posted April 5, 2008 If you looked, it does have a 1300 cover on the side of the engine rather than the YICS cover. Maybe it is a 1300 that someone has replaced the engine with due to a 2nd gear problem. But for this, the bike would most likely have 113,000 miles on it. Then again, maybe someone did not know how to fix the speedometer squeal and replaced it. It does look clean. I am just glad it is WAY too far from Tennessee. RandyA
Squeeze Posted April 5, 2008 Posted April 5, 2008 Or someone just replaced the Clutch Cover Left front is a YICS Cover ...
