Is there a better place to purchase brake pads from other then the stealer?? and what about what kind?? any better then others? Do these ever need the rotors turned?? my bike has 10k on it and am starting to hear the brakes a bit, thought I would change them before the riding really kicks off.. Thanks for any help and advise, also, should I change the fluid out also and what do I put in it.... that answer is probably in the M.O.M. but thats to easy and I trust ya`ll`s input more then what is in the book...
Thanks,
Kreg
I'm on my 3rd Royal Star Venture and 5th Royal Star. They all had the same front brake sqweel. Pads may be ok, check your manual for info on pad thickness. I put some pads behind the brake pads that stop most of the noise on my 2004.:080402gudl_prv: Also two of my Royal Stars had 50000+ miles, never changed a rotor.
