I understand about relays and such. My question is basic.
Did Yamaha have a wire(s) setup in the wiring harness for passing lamp installation? One would think they would have a plug sitting in the fairing waiting for the dealer to plug in the passing lamps! They did supply the optional kit for the physical lamps themselves and the bar to install them.
Or....are we on our own to splice in how we want the lamps to be triggered?
Didn't see any mention of any factory connectors in the older posts....
TIA,
david
your are your own re splicing..factory says wire to high beam...but i say wire direct to relay and switch it on when you want..i wired mine to kuryakyn master cylinder 3 switch that runs hid,passing lamp,and daytime leds..just my $.02.
OEM suggested wiring is thru low beam. I also like to run mine when I want. So it is energized by the aux plug via a relay.
On my '99RSV, the dealer installed a po/po button next to the 12vdc plug on the fairing. I wished that they had used a toggle. I find it a PITA trying to figure out if the running lights are on or off while moving. Someday I may install one....
Yup would have to agree the push on off button is a pain to figure if on or off as there is no indicator light. Shoot most times I cant even find the dang button.
Ditto on that..... :bang head:
