I built a small vacuum reservoir for the MAP sensor. Sent all 4 ports to a union. Then put in the restrictor. At that point I attached the Dingy-Can and then on to the MAP sensor. Succsess!! The voltage readings are stabilized at only a maximum 3% variance. I may need to adjust the voltage values a bit yet. I like my 100% as it is. Running 4.7 volts. The reading taken with the engine off and no vacuum. My lower voltage is currently ar 3.2 volts. It may need a bit of lowering yet. Going.to figure out how to tie down the reservoir then go ride.
