Yep, had a loose dash last year to the point were it was flopping like it was ready to fall off and made a heck of a racket. I think the rubber grommets dry and shrink / breakdown. Someone here suggested adding washers. I added thick SS washers to each side of all the grommets pre season. That totally tightened up dash flop and eliminated most of the rough road bounce racket from the front end. Close to 10,000 mi. and still holding.
Adding washers to the rubber grommets was a Yamaha Tech Bulletin suggestion.
M83-015 Additionnal Predelivery service .pdfFetching info...
I also added washers to the dash grommets. Get a 10mm closed end ratchet wrench to do it. It makes it a whole lot easier !!
