VentureFar Posted September 8, 2015 #26 Posted September 8, 2015 I punched the holes in the filler neck. Did it at a gas station but off to the side. Filled up as much as I could. Ride 50'feet away and took out my rubber hammer and my awl. Punched 4 holes in the filler neck as high as I could and ride back to the pump and put in another 4/10 gallon. When I go on reserve and get gas immediately I squeeze in 4.3 gallons. I get 160 to 180 miles to reserve light with two bars showing. That still leaves me 1.6 gallons to walking at about 36 to 38 mpg at gps 75 mph which is indicated 81 on the speedo. Sincere cruise control will only do indicated 80 to 81 mph I cruise at actual 74-74 mph over the ground. Depending on wind direction or none is 33 mpg to max 42 mpg. But over 20,000 miles of mostly freeway in my 2007 Rsv I plan to average 35 mpg for planning fuel stops. And that's all I have to say about that. VentureFar... Sent from my iPhone using Tapatalk
Great White Posted September 8, 2015 #27 Posted September 8, 2015 I usually get the fuel light at around 180 Km's. city or highway. Fuel mileage has always kinda sucked on my 83.....
BG Hawks Posted September 8, 2015 #28 Posted September 8, 2015 Went for a ride several weeks back; 359 miles and got 41 MPG riding 2 up. Really paid attention to keeping the RPM's up and knocked off any extra rev off the engine at lights and such.
ToyOdie Posted September 8, 2015 #29 Posted September 8, 2015 My bikes are a 96 and 97 RSTC's so there is no fuel gauge. With the tank filled to the top of the neck I can go between 155 and 165 miles before it starts to sputter and I have to switch to reserve. I got lucky one time and it sputtered as I was coming down my street with 156 miles on the trip meter. I had an empty 1 gallon can so I drained the tank to see how much was left. It was just over 3/4 of a gallon. With my average 45mpg, I figure I have around 40 miles left when I switch to reserve.
chag67 Posted September 8, 2015 #30 Posted September 8, 2015 I get 38 mpg but I ride mine pretty hard. Interstate speed is around 80-85 for trips less than 50 miles. 50+ mile trips, I'll avg around 77 mph. Backroads I'm usually cruising around 55. My typical fillup is right at 4.3 gallons and the tripometer is usually at 160-165 miles. I use my bike as a daily commute as well. Riding every day that the rain chance is less than 40%.
Semi-retired Posted September 8, 2015 Author #31 Posted September 8, 2015 I punched the holes in the filler neck. Did it at a gas station but off to the side. Filled up as much as I could. Ride 50'feet away and took out my rubber hammer and my awl. Punched 4 holes in the filler neck as high as I could and ride back to the pump and put in another 4/10 gallon. VentureFar...Sent from my iPhone using Tapatalk I'm guessin there's a joke in here somewhere.....but, sorry, not getting it! :-)
VentureFar Posted September 9, 2015 #32 Posted September 9, 2015 @Semi-retired see the above post? 1/2 gallon not accessible at the top. Ergo punch a few filler neck holes to let the air out- or blow your self up and the gas station too :-) VentureFar... Sent from my iPhone using Tapatalk
Brake Pad Posted September 10, 2015 #33 Posted September 10, 2015 2007 Yamaha Venture mileage also depends on where you live. Hot south Florida, 1 up about 158 miles @ 65 mph 2 up about 152 miles @ 65 mph 2 up pulling loaded trailer at 60 mph 145 miles Goldwing 230 1 up @ 65 2 up 225 @ 65 Mph 2 up pulling trailer @ 60 195 Miles
Semi-retired Posted September 10, 2015 Author #34 Posted September 10, 2015 @Semi-retired see the above post? 1/2 gallon not accessible at the top. Ergo punch a few filler neck holes to let the air out- or blow your self up and the gas station too :-) VentureFar.. Now I get it! I'm not that brave with hammers around gas tanks! I'll play it stock and just gas up a wee bit more often.
VentureFar Posted September 10, 2015 #35 Posted September 10, 2015 On long rides like Iron Butt or solo to Sturgis trying to make "miles" every gas stop is a delay. In Wyoming and Montana sometimes the gas stations are either too close or almost too far. So I plan to get gas 1/2 way through reserve -the extra 4/10 at the top helps in these circumstances. I havent heard of any one blowing themselves up punching the holes but then again they wouldn't be posting that,now would they! VentureFar... Now I get it! I'm not that brave with hammers around gas tanks! I'll play it stock and just gas up a wee bit more often.��
ToyOdie Posted September 11, 2015 #36 Posted September 11, 2015 Keep in mind that there are tubes that go from the petcock inside the tank (reserve tube lower than main tube). It has been said that 1/2 gallon (U.S.) is not accessible. You also lose some of the tank's capacity by space at the top of the tank you can't fill. I drained the tank from the petcock so the 3/4 of a gallon was the remaining "usable" fuel.
eagleeye Posted September 11, 2015 #37 Posted September 11, 2015 You guys that are punching holes in the filler neck, I'd really like to see a picture of what it looks like when your done. I'd consider doing it, but don't want to jump in before I know what I'm getting myself into. I suppose I should look and see if there is a youtube video, huh? Thanks
videoarizona Posted September 13, 2015 #38 Posted September 13, 2015 42mpg. That's 2 up, mostly 4th gear 55 to 65 mph in slight hills. Fun 2 lane ride. Previously, I get around 36mpg solo. So me thinks my wrist is being bad when I'm alone. So went for a ride this morning to see if my right wrist was controllable. Answer: Yes. 41.4 mpg...mixture of 80mph in 5th gear and 55-65mph in 4th gear. Went to see Colossal cave near Tucson...breakfast at Vail Steakhouse. Bad picture...lens must have been crudded up!
