seabeetom Posted August 30, 2015 #1 Posted August 30, 2015 Ok, sounded simple enough when the RSV riders on two wheels told me about the Barons 1 1/2 risers. However, there is no room to put them in because the fairing sits too low to the risers. It needs to lift/tilt up and away from the bars to give at least 1/2" more clearance. I'm guessing the problem is due to the Hannigan rake mod to the front end?? Soooo, I'm guessing that if I can dismount the front panel/fairing maybe I can shim it to give me the clearance I need. Now, I have the fairing and the handlebars off but how do I get the front panel loose from the bike???? The tech manual doesn't help.. !!!! Leave Our Flag Alone !!!!
videoarizona Posted September 2, 2015 #2 Posted September 2, 2015 Tom, there are two threads going on with same question....see the 2nd gen tech area... I answered your question there... david
