The problem is solved with the tepiratury. There is a suspicion that the thermostatically controlled chamber dies.
  • Replies 129
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
What does tepirarity mean. Google does not recognize. There are no thermostatically controlled chamber, other than radiator on a Venture. Radiator does not interface with TCI that I am aware of.
Gary
Gary
I'm guessing he means the temperature sensor, although I don't think that has an input to the TCI either.
edit: on second thought, given his previous posts on temperature running high, I'd say it was supposed to mean he's solved the temperature running warm problem and suspects it's the radiator....
I had an assumption that the ignition chart with critical angles of an advancing was used. Growth of temperature of antifreeze was noticed. Problem in the thermostatically controlled chamber. It is possible to install the thermostatically controlled chamber from Toyota 90916-03063
