mxvet274 Posted August 25, 2015 #1 Posted August 25, 2015 Tried using yamabond without gasket on stator cov now bike won't turn over. I loosened bolts a little and it started rite up. Do you have to use gasket to have thr proper clearances?
venturesome Posted August 25, 2015 #2 Posted August 25, 2015 I think you might have answered your own question.
KIC Posted August 25, 2015 #3 Posted August 25, 2015 Yep. The gasket gives the clearance:080402gudl_prv:.
KISA Posted August 27, 2015 #4 Posted August 27, 2015 Need minimum 1mm for handmade gasket. Yamaha OEM -0.3mm
kinsmd69 Posted August 27, 2015 #5 Posted August 27, 2015 Yep, I did same thing. Need a gasket for clearance.
