Hi. All the lights work on my 86 VR EXCEPT the headlight. The display does not indicate a burnt out laMp, but chained it anyway. The fuse is ok as well. any ideas or advice?
Thanks, Jim
And while you are cleaning the starter switch, clean the HI / LO beam switch. My headlight stops working almost every year and I just have to clean the switch. Cleaning the switch is actually easier than changing the bulb.
My problem was also the switch was dirty. It will not come all the way out unless you pull it out. I just sprayed electrical cleaner in the switch and it has worked ever since. Good luck.
Just bought a 2000 Venture. The high beam switch is not working. Is this hard to replace? Any tips before I dig in to it?
Sent from my iPad using Tapatalk
  • 2 weeks later...
