Mark J Posted August 20, 2015 #1 Posted August 20, 2015 Have a weird issue on my 00 RSTC. The right side mirror has been effectively locked down onto the front brake master cylinder. It looks like someone took a chisel and knocked an indentation on each corner of the locking nut. I've tried bracing the master cylinder with a wrench and then trying to loosen it, but I can't get it to move at all. Any ideas, other than replacing the master cylinder and buying new mirrors?
winston66 Posted August 20, 2015 #2 Posted August 20, 2015 (edited) If the locking nut is indexed with marks in the edges ,It suggests to me that the mirror stand is a left hand thread . If this is so, you would have to reverse the spannering direction in order to loosen (undo) the mirror. Cheers , Winston66, Northampton, Western Australi That means you have to do it up (tighten it) in order to loosen it. Edited August 20, 2015 by winston66 addition
winston66 Posted August 20, 2015 #3 Posted August 20, 2015 Have just checked my 1996 Royal Star and I confirm that the right hand mirror has a left hand thread , which is reversed to normal rotation action, and I also have the index marks on the locking nut which confirms the left hand thread. Cheers , Winston 66
Mark J Posted August 21, 2015 Author #5 Posted August 21, 2015 (edited) Thanks for the information. Didn't know that about indexing. Hopefully I will remember it! Cheers Winston! Addendum: Turned the wrench the "wrong" way, and the locking nut loosened right up. Thanks again! Edited August 22, 2015 by Mark J
