Vonwolf Posted August 8, 2015 #1 Posted August 8, 2015 I’m having problem with my CLASS system, when I put 12 volts to the compressor off the bike on my work bench it seems to run fine and create pressure, but when I install it on the bike it will not pump up the system and I get an E2 error message, the compressor actually blows a small amount of air out of the intake hose so somehow it seem to run in reverse on the bike. Then I'll take the compressor off the bike, put power to it and it works fine, well as good as this little thing can anyway. It's just kind of strange like the compressor works backward on the bike? When I was working on the Compressor I opened the Desiccant canister and of course it was upside down, I had little pink BB's fly all over my dirty floor. It would be really tough to recover the desiccant if that really is what the pink BB"s are so it looks like it's time to replace the stuff. Does anyone know where I can get the correct desiccant for these compressors?
bongobobny Posted August 8, 2015 #3 Posted August 8, 2015 The desiccant is suppose to be blue, and turn pink when wet...
