Semi-retired Posted August 6, 2015 Share #1 Posted August 6, 2015 What risk?? It's a known fact! I'm wondering if any of you have done, or tried to do what I've got in mind by way of Rube Goldberging a pair of inexpensive "prescription goggles".......by buying a pair of cheapy, plain lens ones like this: http://www.amazon.com/dp/B00239X97M/ref=dra_a_rv_mr_hn_it_P1700_1000?tag=dradisplay-20&ascsubtag=06cbc6ea87f55dffbe6d8f832b00fe44_S then having your friendly local optician take the lenses out of your old Peter Fonda-esque, aviator, prescription driving glasses (tinted or otherwise) and grind them down to mount in the 8-buck frames! I GUESS there would be some measuring required......by somebody......somewhere......sometime......but, has anyone ever given this a shot? Call me cheap......but I NEVER wear these old glasses as they are now.....(although I can see fine with them on the road).....and I DEFINITELY need something to keep the air out of my eyes when cruising at 85.....but I would far sooner spend the $400 on gas than on a pair of scrip goggles. There's gotta be a way..........doesn't there???? Link to comment Share on other sites More sharing options...
ragtop69gs Posted August 6, 2015 Share #2 Posted August 6, 2015 The curvature of the old lenses would need to be close to that of the goggles. Ask the doc before you buy the goggles. If it's not possible, you could always just tape the old lenses to your face Link to comment Share on other sites More sharing options...
vzuden Posted August 7, 2015 Share #3 Posted August 7, 2015 If it's not possible, you could always just tape the old lenses to your face I would suggest duct tape for 85MPH:cool10: Link to comment Share on other sites More sharing options...
slowrollwv Posted August 7, 2015 Share #4 Posted August 7, 2015 I wear prescription glasses and they are tinted, they get darker when out side doing anything. I also use a modular helmet and with the shield down the glasses do not get dark du to the ultraviolet rays blocked by the shield. The helmet that I use does have a sun shade in it so that helps. When I am doing 85 MPH the shield is down and locked in place, the wind does not bother me at those speeds. Link to comment Share on other sites More sharing options...
Marcarl Posted August 7, 2015 Share #5 Posted August 7, 2015 Now you've gone and dun it,,,, you sound like a cheapskate. Link to comment Share on other sites More sharing options...
videoarizona Posted August 7, 2015 Share #6 Posted August 7, 2015 Michael, At the risk of knowing I'm cheap and sharing that idea.....my suggestion is to look for goggles like those you linked to, but ones that have room for you to wear your glasses at the same time. Done. david Link to comment Share on other sites More sharing options...
Semi-retired Posted August 7, 2015 Author Share #7 Posted August 7, 2015 Michael, At the risk of knowing I'm cheap and sharing that idea.....my suggestion is to look for goggles like those you linked to, but ones that have room for you to wear your glasses at the same time. Done. david That's the ideal solution, I guess.......if I could just "try them on"......virtually........through eBay/Amazon/whatever, to make sure they fit, before ordering, that'd be GREAT! If only these eyes worked the way they used to, damit! It's unfortunate that along with getting older and wiser.......we also get blinder and feebler! (Oh, and balder and deafer.......need I go on?@%$^$!!) Link to comment Share on other sites More sharing options...
Semi-retired Posted August 7, 2015 Author Share #8 Posted August 7, 2015 When I am doing 85 MPH the shield is down and locked in place, the wind does not bother me at those speeds. Yeah, thanks, man........and....I know I can't have it both ways......but I've ALWAYS been an open-face guy, so some kinda goggles HAS to be my solution I think! Link to comment Share on other sites More sharing options...
videoarizona Posted August 7, 2015 Share #9 Posted August 7, 2015 ((we also get blinder and feebler! (Oh, and balder and deafer.......need I go on?@%$^$!!)) Nope...no need. I'm with you. I would check out the goggles listed below yours...and then check out the Q&A. On your someone did ask if glassed fit underneath....others may do as well. Can't hurt to try...email seller. Link to comment Share on other sites More sharing options...
Semi-retired Posted August 7, 2015 Author Share #10 Posted August 7, 2015 Now you've gone and dun it,,,, you sound like a cheapskate. Don't be rubbin' it in now, Carl!! Link to comment Share on other sites More sharing options...
RedRider Posted August 7, 2015 Share #11 Posted August 7, 2015 What color is the milk crate on your KLR? Get a full face helmet and wear your current glasses. Better protection and cheaper than new prescription glasses. Or, contacts. Then you can wear the standard goggles. RR Link to comment Share on other sites More sharing options...
Beach Bum Posted August 7, 2015 Share #12 Posted August 7, 2015 Walmart will put prescription lenses in just about ant frame you give them starting at $38 for single vision. I had a bunch of Oakley frames with scratched up crap lenses in them that I brought in and had them install polarized single vision lenses. Cost $78 each for those. Link to comment Share on other sites More sharing options...
Squidley Posted August 7, 2015 Share #13 Posted August 7, 2015 Now you've gone and dun it,,,, you sound like a cheapskate. Hows that for insult to injury, a DUTCHMAN called you a cheapskate! Link to comment Share on other sites More sharing options...
ReinyRooster Posted August 7, 2015 Share #14 Posted August 7, 2015 Squid....you took the words right outta my mouth....I had just started typing the same thing! LOL!!! Link to comment Share on other sites More sharing options...
Semi-retired Posted August 7, 2015 Author Share #15 Posted August 7, 2015 What color is the milk crate on your KLR? Get a full face helmet ....... Or, contacts. RR My wife's sentiments, exactly. But.......I'm not a full-face-fan. The contacts approach might be worthy of investigation. (as long as they don't end up exceeding the cost of prescription goggles!! :-) ) Thanks, bud. Link to comment Share on other sites More sharing options...
billmac Posted August 7, 2015 Share #16 Posted August 7, 2015 Go into some bike shops they usually have all types of goggles to go over glasses or not, about $25.00 or less. Link to comment Share on other sites More sharing options...
billmac Posted August 7, 2015 Share #17 Posted August 7, 2015 Oh, if you go into dealers you can get the same ones for $80.oo if that will make you feel better. check with the eye doc to see the cost of your idea. Link to comment Share on other sites More sharing options...
RedRider Posted August 7, 2015 Share #18 Posted August 7, 2015 What I find advantageous about contacts is that I can wear standard sun glasses if I want. Also, since I am an official old fart, I also need readers. With the FF helmet I put one of these stick-on bifocals at the bottom of the faceshield (off center so it isn't in the direct line of sight). Allows me to see the GPS and/or notes in my tank bag window. On LD rallies, I have used single day wear contacts. Dispose of them each night and put in fresh in the morning. RR Link to comment Share on other sites More sharing options...
Karaboo Posted August 7, 2015 Share #19 Posted August 7, 2015 My HJC open face lid has a slide down tinted sun shield, and a flip up clear shield (removed and never used). The tinted shield blocks enough wind at 70 (our speed limits here). Link to comment Share on other sites More sharing options...
Pic Posted August 7, 2015 Share #20 Posted August 7, 2015 I buy Prescription sunglasses from Zenni Optical. Here is the link to what I get, about $65 delivered. Single vision, been using these for years on the bike. Link to comment Share on other sites More sharing options...
Venture n Dixie Posted August 9, 2015 Share #21 Posted August 9, 2015 If you have your Rx there are plenty of online (Chinese) companies with cheap glasses like these for $36. Wife and I have had good results.http://www.zennioptical.com/703318-prescription-wind-goggles.html Link to comment Share on other sites More sharing options...
