blaine1 Posted August 6, 2015 Posted August 6, 2015 has any one had any exp on the Standard XVZ1300 87 and how the work any problems i am looking at one blaine
Marcarl Posted August 6, 2015 Posted August 6, 2015 Best explain what you need and what you think your problems are. There's lots of experience here and we'll try to get it fixed for you.
paysaw Posted August 6, 2015 Posted August 6, 2015 I just did some extensive repairs on a the Class system.Maybe I can help you.
Flyinfool Posted August 6, 2015 Posted August 6, 2015 If it is a standard then there is no class system, You use a small hand pump to adjust the air pressure to your needs.
Prairiehammer Posted August 6, 2015 Posted August 6, 2015 I just did some extensive repairs on a the Class system.Maybe I can help you. The OP concerned the Standard Venture, (no CLASS). To Blaine: what exactly is wrong with the "air ride" now? Loses air? There isn't much to go wrong with a Standard air ride. Pretty much all that can fail are the hoses, shock, fork O-rings or fittings. Check all the air lines with soapy water. Look for small bubbles. Any bubbles indicate a leak. Particularly important to check the hose joints. And the 'Fool beat me with the "CLASS" comment while I was editing my first comment.
blaine1 Posted August 6, 2015 Author Posted August 6, 2015 thanks i have a hard job explain g my self being a back yard woods from nb blaine
