taz112 Posted July 25, 2015 #1 Posted July 25, 2015 I just purchased a 1986 Venture Royal. I am getting a slight miss at 2500 to 3000 rpms. This happens when just reving and not moving. It might be happening when moving and just don't notice. I ran seafoam thru 2 tanks of gas and has gotten a little better. Fuel milage is about 35 mpg. Is this normal? Any suggestions? I did change plugs and put in ngk as in the owners manual. This made no diffence. Sent from my NX785QC using Tapatalk
taz112 Posted July 30, 2015 Author #2 Posted July 30, 2015 I was hoping someone could help me with this problem or at least give me some ideas. Guess I was wrong. Sent from my SPH-D710 using Tapatalk
Great White Posted July 30, 2015 #3 Posted July 30, 2015 Go here: http://www.venturerider.org/forum/showthread.php?71406-83-87-Technical-Training-Service-Bulletins Look at the pdf for low speed misfires. Read the first few paragraphs and they give you guidance on things to check. I had a "lugging" issue between 2000-3000 rpm and a set of NGK iridium's and new plug caps cleared it right up. The plug caps have a bunch of little bits in them (resistor, spring, bras discs, etc) that have been known to corrode and cause issues. Your 86 will already have the "upgraded" ign wires, but they're also 29 years old now so....
taz112 Posted July 30, 2015 Author #4 Posted July 30, 2015 Thank you for that info I will try it and post the results. Any idea on what kind of mpg I should be getting? Sent from my SPH-D710 using Tapatalk
Great White Posted July 30, 2015 #5 Posted July 30, 2015 Thank you for that info I will try it and post the results. Any idea on what kind of mpg I should be getting? Sent from my SPH-D710 using Tapatalk My 83 hovers right around the 34-36 mpg mark around town. Roughly around 38-39 if all highway at around 60 mph.
taz112 Posted July 31, 2015 Author #6 Posted July 31, 2015 I guess the 35 is not to bad for stop and go. Thank you!! Sent from my NX785QC using Tapatalk
blaine1 Posted August 2, 2015 #7 Posted August 2, 2015 (edited) my 87 is doing the same thing i ran 2 cans of sea foam in 3 tanks of gas is still doing the miss at 2500 to 3500 only at cold when hot not a lot i changed the plugs before i started am in the process of changing them again when i get the parts will let you know if it works the bike goes real good beside that it was real bad when i got it thought it was worth it with only 39000km blaine just put new plugs it works a lot better have a little popping sound at idle going to try a other can of sea-foam one plug was a little wet other was dry blaine Edited August 5, 2015 by blaine1
blaine1 Posted August 6, 2015 #8 Posted August 6, 2015 3 cans of sea foam change the oil 4 times the plugs 3 times wow what a bike just have to syn will let you know blaine it sat for 5 years
taz112 Posted August 13, 2015 Author #9 Posted August 13, 2015 So I think I have found that the miss is a mixture problem that is not a problem. Under load it runs fine and was advised not to mess with mixture as it could make things really bad. I have noticed that this engine is really cold blooded! Has to warm up almost 20 minutes before it quits stalling. Think my winter project will be to rebuild carbs. Any one know what it would take to change to fuel injection if possible? Sent from my SPH-D710 using Tapatalk
