I picked up one of the ignition switch relays that were being sold on here. Trying to find the article on best way to install. Thought someone even posted a youtube video. Any help would be appreciated on where to find it
I just did mine with the same setup. Super simple. Pull the tank off and you'll see the plugs where the bypass relay plugs in. Connect the ground and you're good to go. I connected the ground wire to a clamp bolt just below where the relay connects. :happy34:
Where are the relays for sale at?
Mike
Drop me a pm. They are in the vender member area, but not always the easiest to find there. Just drop me a PM and I will shoot you my e mail. The standard is $25 and keyless is $33. Pay Pal is about the easiest.
