Mikealiasmike Posted July 19, 2015 #1 Posted July 19, 2015 I picked up one of the ignition switch relays that were being sold on here. Trying to find the article on best way to install. Thought someone even posted a youtube video. Any help would be appreciated on where to find it
M61A1MECH Posted July 19, 2015 #2 Posted July 19, 2015 Get a hold of Dion, djh3 here on the forums, he should be able to fix you up. this link should get you to his profile. http://www.venturerider.org/forum/member.php?10574-djh3
uncledj Posted July 19, 2015 #3 Posted July 19, 2015 I just did mine with the same setup. Super simple. Pull the tank off and you'll see the plugs where the bypass relay plugs in. Connect the ground and you're good to go. I connected the ground wire to a clamp bolt just below where the relay connects.
djh3 Posted July 19, 2015 #4 Posted July 19, 2015 Trying to figure out how to attach the PDF I have. Instruction sheet 2nd.pdf
Mikealiasmike Posted July 19, 2015 Author #5 Posted July 19, 2015 Thanks everyone.! Just what the Dr. Ordered
MikeWa Posted July 19, 2015 #6 Posted July 19, 2015 I picked up one of the ignition switch relays that were being sold on here. Trying to find the article on best way to install. Thought someone even posted a youtube video. Any help would be appreciated on where to find it Where are the relays for sale at? Mike
djh3 Posted July 20, 2015 #7 Posted July 20, 2015 Drop me a pm. They are in the vender member area, but not always the easiest to find there. Just drop me a PM and I will shoot you my e mail. The standard is $25 and keyless is $33. Pay Pal is about the easiest.
