starts well(new battery) but idle speed increases as it warms up) Has someone have any idea bike has been setting for a while blaine
i am looking to buy the guy told me this when i talked to him it has 39000 k on it will here it for my self in the morning will let you know blaine
i bought the bike turned the idle down sea foam will let set for the night the air ride pimps but will not hold have to pump it up every time any thoughts what to look for blaine the body is a little cracked ant tires are bad only paid 1200 for it so i have a little leaway
For the air suspension, make yourself a little soap and water solution in a squirt bottle. Then trace down all the places there's joints in the air lines. Squirt a little of your solution on the joints and when/if it bubbles you've found your leak...
