KSRIDER10 Posted July 10, 2015 #1 Posted July 10, 2015 Greetings everyone, Does anyone here know, or know where to find the procedure to time Vmax cams in Gen2 Venture heads mounted on a Royal Star block?
dingy Posted July 10, 2015 #2 Posted July 10, 2015 PDF attached. GaryVMX12- Service-Manual Cam install.pdf
KSRIDER10 Posted July 10, 2015 Author #3 Posted July 10, 2015 Gary, AWESOME! Thank you. One thing, are the cam sprockets the same for the two motors and can I use the Venture valve springs (duals) with the Vmax cams?
dingy Posted July 11, 2015 #4 Posted July 11, 2015 Gary, AWESOME! Thank you. One thing, are the cam sprockets the same for the two motors and can I use the Venture valve springs (duals) with the Vmax cams? As far as I know cam gears are the same. I think they are marked intake & exhaust. I would not use Venture springs though. The VMax springs are heavier return rate, thus allowing higher reving of motor. Prior to putting VMax heads on Tweety, valves would float around 8300 rpm. It can do 10,000 now, primarily due to better valve springs. Gary
