Here is the part number for the entire assembly. 4WM-24500-10-00 You can get more specific parts if you don't need the whole unit. YamahaPartsHouse.com (Babbits.com) is where I have bought many parts.
Almost 20.00 cheaper with Partshark! Making sure it's the correct part on Monday but sure think it is. TYVM KSRIDER! I owe you a beverage. Bookmarked it for future reference if I need it.
Partshark.com is less expensive however.....in my experience they are not very quick in shipping and their customer service leaves something to be desired. Based on your other post, you said one of the brass tubes had come out of the housing. Those are just press fit in the housing (no sealant required). If the tube is not damaged, all you should need to do is put a small piece of wood over the end of the tube and tap it back in. I have had the same issue with mine. Tapped it back in and have had no problems since.
