Applied final coat of Silver and three coats of clear.. removed masking and then reassembled it.
Now Im waiting for it to dry before I remount it on the bike.
The screwdriver is holding lid from trunk so the seam area can dry properly...
Now you can come up and do mine.....:innocent-emoticon::mugshot:
Let me know when you have it all sanded down Dan and I'll come up and do it for you. :beer:
did you use a spray can or gun?
Just a spray can of silver paint then a spray can of clear from WalMart.
I'm sure the trunk will get a few nicks and bumps here and there from debris off the rear tire anyway, so I'm not to interested in a professional paint job on it.
Thanks Buddy. Not surehow much painting to be done yet. A good decal of some type a little bigger than a softball would keep me from painting the Faring. Missing one driving light and a antena and mount but its not bad. I took the worse of this one. I hit hard!!Two bike accidents and two cage accidents in the last 10 yrs makes you think a little.
Dan you can always try to catch up to @cowpuc on sticker count and not have to paint nuttin.
I bet that Cowpuc could even tell just where to go to get the perfect sticker for that spot. I know Puc is always telling me where to go......:stirthepot:
Well, here is the finished product.. I gave it another clear coat today and touched up a couple spray can spits & sputters.
I just now got it re-installed on my wing where it is drying.
:clap2::clap2::clap2::dancefool::dancefool::dancefool::dancefool:
THAT is GORGEOUS ECK!!:clap2:
May sound crazy but I have often wondered why manufactures dont do exactly what you have done my friend.. At least take a good hard look in RnD and how placing the trunk of these touring bikes down at that level to lower the center of gravity.. I REALLY like that Eck!! NICE JOB!!:thumbsup:
Eck, is that the same color as the 05 RSV has? Sure looks close. If so...can you let out where you got paint and what color number?
I have some painting I want to try on my 05....and she is silver.
Thanks,
david
YEP !! Time for that extra wheel me thinks
David,
The spray can of paint I used was "Rustoleum - Satin Nickel ". It has both primer and paint in same can.. Here is a picture of the can and you can get it at Wally World, Lowes, Home depot or most anywhere for about $6 bucks a can. Then I used Rustoleum crystal clear enamel.
So what trunk is that off of ? Looks great. I am thinking of taking the trunk off of my 87 and building a hitch bolted frame to mount a second trunk on it for a trip. Easier to haul than a trailer. How is yours connected/bolted on to your bike ? :confused24:
Answers Eck answers !! Venturing minds want to know...
(1) So what trunk is that off of ? I have no idea.. It is a scooter trunk. A guy gave it to me.
(2) Looks great. Many Thanks!!
(3)How is yours connected/bolted on to your bike ? :confused24:.......I used a piece of aluminum diamond plate and mounted it to my own self made trailer hitch. Then I mounted two (measured and cut to length) drawer slides to the diamond plate. Then I mounted the trunk to the slides. I then made a locking mechanism to hold the trunk in the fwd position when riding, or I can unlock the mechanism and slide the trunk aft to get into it.
Hope this helps. If you are interested in how to, send me an email and I will forward you my phone number and walk you thru it if you want.
