eds Posted June 13, 2015 #1 Posted June 13, 2015 Rode for hour or 2 and stopped for lunch came out and all I had was radio. After several attempts bike did start 2005 RSV hannigan trike and was good the rest of the day 2 or 3 stop and starts. Now this morning again only the radio no lights or dash.
Freebird Posted June 13, 2015 #2 Posted June 13, 2015 Sounds like the notorious ignition switch failure.
eds Posted June 13, 2015 Author #3 Posted June 13, 2015 I installed the bypass per Carbon Ones instructions a couple years ago with a toggle switch. I flipped the switch and have power across it, but nothing went on. Is there something else I am missing?
CATPower Posted June 14, 2015 #6 Posted June 14, 2015 Power goes from Battery to starter solenoid and fuse through a connector (red wire) to the ignition switch (on position) to fuse block #2 (brown/blue wire). Somewhere on here (this site) are the schematic for it.
