pcdocs2 Posted June 12, 2015 #1 Posted June 12, 2015 Hello All And Pls. Help. My RSTD Wont Run in Third or forth or Fith Gear I Have A Royal Star Venture Just Bought A 2006 Yamaha Royal Star Tour Deluxe. And I am Having Problems With It. I Bought it from a Man who got it from a insurance salvage yard. The Man Talked to The Owner and He Said it was a Great Bike. But The Bike was at the insurance salvage yard Had Been stolen From the Guy. And Wrecked Just Broke the Passing Lights and Lower FAIRING COWL one Crash Bar. But His X Girlfriend Also Took A Hammer to the Fenders Tank and Speedometer. Broke the Speedometer. But Now it Wont Run Right. It Runs Great Fast in First and Second But when I Shift to Third or forth or Fith Gear it is Like I Loose Power.Like Not Getting Fire. But it Powers On When I Pull in the CLUTCH in any Grar. But will Not Run When I Let Out The CLUTCH in 3-4-5 Grar No Power to Make It Run. Does the Speedometer Being Broke Keep It From Running in 3-4-5th Gear? And Is There any Sensor or Relays or Speed Sensor or Clutch Switch Or Any Other Switchs. That May need To Be Replaced? Can Any One HELP Me Out?
kevin-vic-b.c. Posted June 12, 2015 #2 Posted June 12, 2015 So this is when you are out on the road riding then correct? If so I would venture to say fuel pump. Just my guess.
Kirby Posted June 12, 2015 #3 Posted June 12, 2015 Another possibility is that you may be missing on 1 or 2 cylinders. You'd be amazed at how good a 4 cylinder such as these run on 3 cylinders. When you first start the bike, quickly touch each of the exhausts and see if they are all the same temp. Hope this helps.
Patmac6075 Posted June 13, 2015 #4 Posted June 13, 2015 Need more precise info....can you run it all the way to redline in 1 & 2? How about going up a steep hill in 1 & 2, does it still have similar power? When you say loses power in 3-4-5...is it bogging and sputtering or is just a straight cut of engine? What about very slow speeds shift into 3rd? What do the plugs look like (pix whould be nice)? Just trying to distinguish between electrical issue, lean issue, fuel supply issue (which I guess, technically is a lean issue). Have you done any work on the bike since it was known to run well....replaced anything? That's how I would approach it......
pcdocs2 Posted June 17, 2015 Author #5 Posted June 17, 2015 Hello All an Thanks For Your Help. I have Reset Flots and used a Quad carburetor synchronizer kit.For syncing My carburetors. I have Changed out the fuel pump even tryed a Car Elc. Fuel Pump. But No Change. I Have All The Lights off Replacing and Fixing the Passing Lights and the Blinker Lights. and have the Broke Speedometer apart trying to get it to work but it is junk i think. I have touch each of the exhausts at Start Up and all the same temp HOT. An here some pics of the bike when i got it. The Guys X Girlfriend Also Took A Hammer to the Fenders Tank and Speedometer. Broke the Speedometer Took and Knife and Cut all the Seats and Puts so so on[ATTACH=CONFIG]100092[/ATTACH][ATTACH=CONFIG]100093[/ATTACH][ATTACH=CONFIG]100094[/ATTACH][ATTACH=CONFIG]100095[/ATTACH][ATTACH=CONFIG]100096[/ATTACH][ATTACH=CONFIG]100097[/ATTACH].
Patmac6075 Posted June 18, 2015 #6 Posted June 18, 2015 I'm still confused about how it's losing power....is it pulling strong in 1 & 2? All the way to redline? Is it bogging in 3-4-5 or cutting out? Might be worthwhile to change out the fuel filter...crazy girlfriend might have put something in fuel that has it slightly clogged? Might drain all the old fuel out too... My bike sat for 10 years and as I was recommissioning it I did all the routine maintenance except I failed to drain about a gallon of stale fuel...bike started up great, but just sort of faded after 5k rpm...ran a couple of tanks of clean fresh fuel through and the power progressively came back.
pcdocs2 Posted June 18, 2015 Author #7 Posted June 18, 2015 Thanks all and Pacmac6075 for your Help. When i test drive it i rave the motor dump the clutch burn out in first hitting the Rave limiter clutch it hit Second Burn the tire hitting the Rave limiter Again. Hit The clutch and shift to Third or forth or Fifth Gear and it is like i just let off the Throttle even if i pull the chock out it just Idles..Until i pull the Clutch in then it Raves up.. But Wont Power On in Third or forth or Fifth Gear.. It Pops sometimes in Third or forth or Fifth Gear but not always. But when it slows back down i shift it back to First or Second. Hang The Hell On.... *Grins* And Also New Tank and fuel filter and Fuel Pump and Lines. And New Fuel....
Patmac6075 Posted June 18, 2015 #8 Posted June 18, 2015 (Scratching my head!), Well, I'm beginning to believe you've got an electrical issue and not a fuel issue, perhaps something related to your speedo/dash, as you had originally suggested. I'm not very knowledgable about electrical issues, and I know even less about Royal Stars My suggestion would be to repost in the Royal Star Tech Talk section, let them know what has already ruled out. Sorry I could have been more help
pcdocs2 Posted June 18, 2015 Author #9 Posted June 18, 2015 Thanks Pacmac6075 your still Help telling me where to repost Thanks Again
Venturous Randy Posted June 20, 2015 #10 Posted June 20, 2015 Maybe the evil witch put a curse on the bike. Randy
pcdocs2 Posted June 20, 2015 Author #11 Posted June 20, 2015 Way Funny Venturous Randy I Guess I Need to Rewatch the Movie >>>---> The Exorcist and Get That Mean Bit*** Curse off the Bike.. Love The Saying You Have Randy Ride as though you are invisible, not invincible. Hero's don't wear capes, they wear dog tags. AMEN BRO.
Beau-Kat Posted June 22, 2015 #12 Posted June 22, 2015 pcdocs2 said: Hello All And Pls. Help. My RSTD Wont Run in Third or forth or Fith Gear I Have A Royal Star Venture Just Bought A 2006 Yamaha Royal Star Tour Deluxe. And I am Having Problems With It. I Bought it from a Man who got it from a insurance salvage yard. The Man Talked to The Owner and He Said it was a Great Bike. But The Bike was at the insurance salvage yard Had Been stolen From the Guy. And Wrecked Just Broke the Passing Lights and Lower FAIRING COWL one Crash Bar. But His X Girlfriend Also Took A Hammer to the Fenders Tank and Speedometer. Broke the Speedometer. But Now it Wont Run Right. It Runs Great Fast in First and Second But when I Shift to Third or forth or Fith Gear it is Like I Loose Power.Like Not Getting Fire. But it Powers On When I Pull in the CLUTCH in any Grar. But will Not Run When I Let Out The CLUTCH in 3-4-5 Grar No Power to Make It Run. Does the Speedometer Being Broke Keep It From Running in 3-4-5th Gear? And Is There any Sensor or Relays or Speed Sensor or Clutch Switch Or Any Other Switchs. That May need To Be Replaced? Can Any One HELP Me Out? Sounds kinda like my Ist gen issue here: http://www.venturerider.org/forum/showthread.php?101878-Engine-won-t-rev-past-about-4600rom
