az1103 Posted June 7, 2015 Posted June 7, 2015 [h=2] Earshattering static[/h] I am getting ear shattering bursts of static in my helmet speakers when accelerating and typically at the same RPM. It is intermittent and seems to go away and reappear. Today when I began our ride it was at 4500 RPM for about 15 minutes, then it totally disappeared. In about an hour and a half, or so, I started hearing an occasional pop intermittently on acceleration. Then it became a full blown ear buster at around 3000RPM. It seems related to the ignition system but I thought I would post the problem in case someone has had a similar problem and can point me in the right direction before I start haphazardly tearing things down !
djh3 Posted June 7, 2015 Posted June 7, 2015 Yea I have experienced some static in the intercom off and on. Now if I dont have the navagator with me, turn down the IC to 0 and it goes away. Mine primarily is heard when the handle bars are turned to make a left. I have been told it has to do with where the radio\intercom cables are routed. Also suposedly cleaning the connectors and adding some dielectric grease helps. I have not elmininated it, but is less than ituse to be.
