Mr_D Posted June 5, 2015 #1 Posted June 5, 2015 I have something that puzzles me. My bike will run after you drop it into gear with the kick stand down. But one thing I learned tonite puzzles me. I had to set the bike down on its side after I lost my fotting. After standing it back up it had drooped the bike into gear. Even when I pulled in the cllutch it would still not start. I either had to pull the kick stand up to get the starter to engage with it in gear or else put the bike in nuetral to get the starter to engage, what am I missing
djh3 Posted June 5, 2015 #2 Posted June 5, 2015 Should not start or run with side stand down and in gear, to prevent you from riding with side stand down and high centering off it. Only thing I can think of on your deal is maybe it set the "tip over" switch.
Marcarl Posted June 5, 2015 #3 Posted June 5, 2015 Sounds like it's now working the way it's supposed to. I would check and clean the side-stand switch for starters, and also maybe the clutch switch.
Condor Posted June 5, 2015 #4 Posted June 5, 2015 Your lay-down kill switch is stuck. The bike still thinks it's horizontal....
