Cowboy Posted May 31, 2015 Posted May 31, 2015 Need info on how to fix an oil leak at the shifter shaft as it comes out of the transmission. I have been having oil dripping for awhile now. I finally found the culprit today. Know just need to know how to go about fixing. Anyone know what it takes? Thanks ahead of time. Brian
ragtop69gs Posted May 31, 2015 Posted May 31, 2015 Pull the linkage off the shift shaft, pull the middle gear cover and replace the seal . a small hooked tool like a dental pick is how I got the old seal out, slide the new seal as far into the bore as you can then slip a washer and short section of pipe over the shaft and use it to drive the seal home.
Cowboy Posted June 4, 2015 Author Posted June 4, 2015 Jay, Thanks for the knowledge. I ordered the oil seal and will replace in the morning. I was not sure how to remove the oil seal but it just came right out with a pick. New one should just slide back on and tap in place. Thanks again. Brian
ragtop69gs Posted June 5, 2015 Posted June 5, 2015 Don't worry too much when you put the new seal in, it will leak a little till you get the cover back on to support the outer end of the shaft.
Cowboy Posted June 8, 2015 Author Posted June 8, 2015 Jay, One thing I should mention that after 109,000 miles seems that the seal is frozen. I ended up taking a slender long screw driver and hammer. Making sure not to damage the outside walls. It was a pain and after deforming the original seal I was wondering if it would ever come out. Got no damage and new seal in and no oil leaks. Thanks Brian
