I am looking at installing the C/D Moonshinz on the front and the Dynamic cluster2 on the rear.
Are any of our members running these?? What are your thoughts on them?
I already have LED bulbs in the sockets front and rear. I have already modified the T/S flasher for LED's
as well as the LED stop/tail LED board.
I am always looking for any thing that will make us more visible to the cager's.
Ken
I installed a pair for the front and they work great- except I had to modify them a little bit to work in the housings . If I remember right I had to shave off a little on the back side to make them fit on my 2013 RSV. Other than that, they light up great and turn to amber when turn signal is activated.
I've had them on my RSV for many years now, still running brighter than stock. They will flash faster than stock if no load equalizer installed. I've had car drivers tell me "hey I noticed your signal lights blink fast.. (thinking the other bulb is blown).." Well at least they "saw" the signal light, thanks! I orignally had white ones in the front (permissable by law here) but later replaced them with ambers as the white ones blended in a little too much with the LED highway lights..
A super Bright tail / brake light is also indispensible..
I'm running both. Have for 4-5 years now. No problems, plug & play install lots brighter than stock. Well worth it.
