GolfVenture Posted May 3, 2015 Posted May 3, 2015 A Friend passed me this... I've not tried it... “Machinist’s Workshop” recently published information on various penetrating oils. The magazine reports they tested these products for break out “torque” on rusted nuts and bolts. A subjective test was made of popular penetrating oils, with the unit of merit being the torque required to remove the nut from a “scientifically rusted” bolt. Average torque load to loosen nut: No Oil used ……………………516 foot pounds WD-40 ………………… ……..238 foot pounds PB Blaster …………………….214 foot pounds Liquid Wrench ………………….127 foot pounds Kano Kroil …………………….106 foot pounds ATF/Acetone mix…………………. 53 foot pounds The ATF/Acetone mix is a “home brew” mix of 50/50 automatic transmission fluid and acetone. Note this “home brew” released bolts better than anycommercial product in this one particular test. Our local machinist group mixed up a batch, and we all now use it with equally good results. Note also that Liquid Wrench is almost as good as Kroil for 20% of the price. ATF/Acetone mix is best, but you can also use ATF and lacquer thinner in a50/50 mix. ATF = Any type of Automatic Transmission Fluid. This version of the story was in one of the Military Vehicle Club newsletters
Flyinfool Posted May 3, 2015 Posted May 3, 2015 The acetone and ATF does work well, but be careful, acetone will damage some plastics and paints. A drop or 2 is all you need, having it running all over does nothing to help break loose the bolt. By using just enough you have less chance of spillage damaging other things.
slowrollwv Posted May 3, 2015 Posted May 3, 2015 I shave seen this post a few years ago. Have been using ever since. I told a few friends about it and they use it also.
Yammer Dan Posted May 3, 2015 Posted May 3, 2015 As Jeff Says be very carefull with acetone.. It does work better than anything but also doesn't take much of it to damage plastic.
eagleeye Posted May 3, 2015 Posted May 3, 2015 Good post! I've made it and used it, but be careful what you store it in. I couldn't figure out what that red liquid was leaking out of my chemical storage unit. Well, that's what is was. (stored in a plastic spray bottle)
Yammer Dan Posted May 3, 2015 Posted May 3, 2015 (edited) I've never kept any on hand and should. What is best to store it in?? I know glass would be great but some of the small cleaner bottles we throw away could work?? Hard to figure which ones to trust. Edited May 4, 2015 by Yammer Dan
slowrollwv Posted May 3, 2015 Posted May 3, 2015 I have used acetone for 36 years at work. Have brought a lot of it home. Store it in Pepsi bottles with no problem and mix it in a spray bottle a little at a time.
Pegasus1300 Posted May 4, 2015 Posted May 4, 2015 isn't fingernail polish remover basicly acetone? If it is you could use one of those bottles.
jimmy99 Posted May 4, 2015 Posted May 4, 2015 isn't fingernail polish remover basicly acetone? If it is you could use one of those bottles. It is available with and without acetone. That is a great idea for a source of it, going to raid my wife's supply
Monty Posted May 4, 2015 Posted May 4, 2015 How about a small steel oil can with a trigger? You can find them just about anywhere.
eagleeye Posted May 4, 2015 Posted May 4, 2015 How about a small steel oil can with a trigger? You can find them just about anywhere. That sounds like a good option to me.
Semi-retired Posted May 4, 2015 Posted May 4, 2015 Based on ALL the comments here......I'm gonna say that, based on the (tiny) amount needed and the (corrosive) impact on any potential storage container........the first thing that comes to my mind.......to satisfy BOTH requirements.....is a glass bottle with a glass eyedropper. (I guess a nosedropper and/or and eardropper fall into the same category.) The only possible caution being that the "squeeze-bulb" on most of these "droppers" is rubber....which might NOT be as hearty as the glass part, so try not to suck up more than about half a tube's worth.......and don't invert, if you can possibly help it. Thanks for the tip on the fluid combo......whoever got this thread started!
