Mover Posted April 21, 2015 #1 Posted April 21, 2015 Hi, I've had a Battery Tender Jr for about 5 years that the Venture is plugged into when not in use. Recently when first plugging into the electrical outlet the light will flash green very rapidly. That might last for about 10-15 seconds then it will slow back down to the usually alternating red and green until it goes to steady green. I checked the connections at the battery and they are tight. I haven't found any info on the Deltran website to indicate what this rapid green flashing might be so thought I'd ask here. Thanks
Money Venture Posted April 21, 2015 #2 Posted April 21, 2015 GREEN LIGHT FLASHING – When the green light is flashing, the battery is greater than 80% charged. For BT Plus models the red light will also be on steady. (Note: Does not apply to the 8V Plus or the 6V Junior).
Mover Posted April 21, 2015 Author #3 Posted April 21, 2015 GREEN LIGHT FLASHING – When the green light is flashing, the battery is greater than 80% charged. For BT Plus models the red light will also be on steady. (Note: Does not apply to the 8V Plus or the 6V Junior). This flashing I've seen because I've used the BT Jr continuously for almost 5 years however what I'm experiencing is a extremely rapid flashing that has only started to occur recently. Thanks though.
