I've been having an issue with my ignition switch, feels odd when I turn the key and I get nothing but the radio on. If I play with it and get it between accessory and run, I can get everything on. No with this new issue, the bike wouldn't start.... Turns over great but wouldn't start. Pulled rear plugs and no spark. Could the key issue have anything to do with the bike not starting ? I also checked the ignition fuse, was good but swapped for a new one anyway. Waiting for the keyless bypass from Dion as I found no switches on eBay. At a loss here.... Bike was fine 3 days ago when I last rode it
Yes Scott unfortunately the ignition switch can just go bad. Try Pinwall for a replacement used one or spring for a new one.
Get it fixed soon so you can ride with the rest of the WNY crew!
