RoyalRider05 Posted April 15, 2015 Posted April 15, 2015 Hello all, I have no spark (or very little if anything) coming from i believe cyl number #1 (right rear of motor) I took out the spark plug and put it to the frame...nada. I took out the other rear cyl spark plug and BAM...tons of spark. Can anyone confirm this is a coil? I cleaned the connectors at the bottom with some steel wool....still nothing. Any help is much appreciated! Thanks R
Du-Rron Posted April 15, 2015 Posted April 15, 2015 Right Rear Cyl is #3 . Try swapping coil electrical input connector from #3 to #1 coil. Cyl #1 is left rear. If now have spark at #3 then it was a not a bad coil. If still no spark check to see if innards of cap are corroded by taking apart with a screwdriver. Verify cap is screwed onto spark plug wire and clean.
RoyalRider05 Posted April 15, 2015 Author Posted April 15, 2015 Just checked the cap..its cleans as a whistle....I ordered a used set of coil off ebay. Ill try swapping the wires and check for spark tomorrow. Thanks for the input!
RoyalRider05 Posted April 18, 2015 Author Posted April 18, 2015 Got 2 used coil thank goodness. Installed the first bad one....worked....the other rear coil failed!!!!!!!!!!!! So i swapped it and up and running...what a nightmare!! Thanks for the feedback
Winddancer Posted April 19, 2015 Posted April 19, 2015 Had the same thing happen to me, fixed #3 coil and then #1 died a few days later.swapped that out too.. 8 months and 25k later #3 just died again..and these really are a nightmare to change out.
RoyalRider05 Posted April 23, 2015 Author Posted April 23, 2015 Yep...had a hell of a time getting it in and out but it worked out.
