DarkHorse9825 Posted April 6, 2015 #1 Posted April 6, 2015 Has anyone used a Bluetooth receiver plugged into the sterio to stream music from an iPod or iPhone? I want to avoid unnecessary wires. If so, which receiver did you find worked the best?
cecdoo Posted April 6, 2015 #2 Posted April 6, 2015 Thanks for this post, I have been thinking about doing the same thing! Hopefully someone has already done it. Craig
sfcrader Posted April 6, 2015 #3 Posted April 6, 2015 I use this with my IPod so both Bluetooth headsets (Sena 20) can hear the music, works great. http://www.monoprice.com/Product?c_id=108&cp_id=10823&cs_id=1082703&p_id=9722&seq=1&format=2
Flyinfool Posted April 6, 2015 #4 Posted April 6, 2015 I use a cassette adapter. Plugs into the I pod and the wire goes to a cassette looking thingy that goes into the cassette deck. This also works great.
djh3 Posted April 7, 2015 #5 Posted April 7, 2015 I built a Y cable to go up under the fairing. So phone or GPS mp3 what have you play on AUX.
DarkHorse9825 Posted April 7, 2015 Author #6 Posted April 7, 2015 Thanks for the replies. I have used the 3.5mm wired connecter from my iPhone and iPod and plug it into the Cassette deck. I I just want to eliminate the wires; and I don't want to have to split the fairing to install anything else. I know I can use the wireless Bluetooth receiver in the 3.5mm port on the deck, I was just wondering if anyone had a make/model preference. I don't want to spend money on a unit that will only last a short period of time. I might just go buy the iSimple system, but they cost crap load of money for what you get. Thanks again for the replies.
videoarizona Posted April 7, 2015 #7 Posted April 7, 2015 I went this way...tiny little thing. http://www.amazon.com/gp/product/B0059M4G9K/ref=od_aui_detailpages00?ie=UTF8&psc=1 david
cecdoo Posted April 7, 2015 #8 Posted April 7, 2015 I am going to try this one? http://www.amazon.com/dp/B00KXYXXK2?psc=1 Craig
djh3 Posted April 7, 2015 #9 Posted April 7, 2015 One problem I see is your going to have to A: mount it B: charge it I didnt feel to input signal was loud enough from the GPS and Phone when plugged into the AUX port. I have a Boosteroo so I tried that inline. Works great and improves the bass some and clears it up so you dont have to run as much input volume which somehow seems to distort when you jack the phone way up. So same problem, Boostroo works off a couple 4a batteries. And I didnt want the boostaroo mount and dismount when I parrked the bike etc. So I mounted it uner the fairing. So what do I do for power now? I ordered a Waterproof DC/DC Converter 12V Step Down to 3V converter. I built a battery eleminator and soldered this to it. I used a small dowel and wrapped wire around it and soldered this gizmo in. Hook up to keyed power under fairing and wa-la power. Just sayin, if you mount your little bluetooth thin up under and power it, it will be there when you come out of the store or motel and you wont have to turn it on or worry about charging. Who knows they may have some kind of DC charger they build for them.
DarkHorse9825 Posted April 7, 2015 Author #10 Posted April 7, 2015 Thanks for the input peeps. I will try the Bluetooth receiver and see how it goes (they arent' that much $$) If that doesn't work i see that iSimple has come out with some new products that look interesting, even though they are corded (http://www.isimplesolutions.com/)
RedRider Posted April 7, 2015 #11 Posted April 7, 2015 If you get the splitter, you can store the BT receiver inside the faring. Doubt it is waterproof, and it will clean up the look. RR
XV1100SE Posted April 8, 2015 #12 Posted April 8, 2015 Advantage of the iSimple (from Yamaha) is that you can control or skip tracks using the bike's controller. If you use a bluetooth adapter or thru the AUX input you have to reach to the the iPod/iPhone, this will take your eyes off the road.
cecdoo Posted April 8, 2015 #13 Posted April 8, 2015 Advantage of the iSimple (from Yamaha) is that you can control or skip tracks using the bike's controller. If you use a bluetooth adapter or thru the AUX input you have to reach to the the iPod/iPhone, this will take your eyes off the road. This will not be a problem for me, when I ride alone I just set the music and never need to touch it other then the volume. When my wife is on the back she will have the phone and control the tunes. Craig
videoarizona Posted April 8, 2015 #14 Posted April 8, 2015 (edited) For my bluetooth and phone charging...I bought a DelTran Battery tender USB output. I keep it in the pouch and use the two pin Battery Tender plug to power the usb...which powers the bluetooth/phone/mp3 player. Since the bluetooth and mp3 player go all day, the phone is my biggest problem...especially if I'm using the mapping and gps functions. https://www.denniskirk.com/283934.sku?utm_source=google&utm_medium=cse&gclid=Cj0KEQjwgI6pBRDak6aRovWNqLsBEiQA8zZSLkmKVPKStyloHh-Sr-w8OZySRqzDhDhdEVtPRz9hc90aAl6a8P8HAQ david Edited April 9, 2015 by videoarizona spelling, of course...
