Rip Posted March 27, 2008 #1 Posted March 27, 2008 so ... the engine guard size must be larger than 1" diameter. I ordered a set of Kuryakan highway pegs...with 1 inch mounts. Now what? can I use them any way, and just tighten them down as far as they go?
SaltyDawg Posted March 28, 2008 #2 Posted March 28, 2008 The guards are 1 inch I would close the highway peg clamps and measure them to make sure they are actually the right size. I got a set a barons risers for my wifes mc that had one side 7/8th and the other one 1". You don't want them to be exactly 1" because then they won't tighten down enough to keep from moving. They should be about 1/16 of an inch smaller than the bars.
Pilot Posted March 28, 2008 #3 Posted March 28, 2008 Yup 1 inch check to see if you received the wrong ones, you might have the 7/8 inch size.
Rip Posted March 28, 2008 Author #4 Posted March 28, 2008 thanks for the replies--glad to know I didn't order the wrong size. When the clamps are closed the inside measurement on each one is 15/16's. I'll have to look at the engine guard again to see if maybe I was trying to put it on where there was a slight curve. I noticed there wasn't a great amount of option as to where to mount them. --Rip
SaltyDawg Posted March 28, 2008 #5 Posted March 28, 2008 Yeah you have to watch out for the curve and it does limit the placement of the clamps. Glad you got the right size.
