OK guys, I am trying to search will no luck, for a small type 12 volt switch
that has a spring on one end and when the spring is pulled the switch will
make contact. I will keep searching maybe I am typing the wrong words in.
( just for another project :-)
Thanks
Jeff
If it were used on 1st gen it would be NO SPST SPR RTN.
2nd gen uses a brake relay, then a NC SPST SPR RTN. (Normally Closed, Single Pole, Single Throw, Spring Return.)
But a Venture with cruise needs 2nd set of contacts for cruise cancel.
Gary
