What else should I replace while I have the front end torn down? We're talking a 2001 RSV with 73373 miles on the clock.
I know fork seals, whats the preferred make & P/N ?
What about the bushings? How do I know if they need to be replaced?
How do I choose a fork oil weight?
Head bearing repack will be done and possibly add a zerk to keep them lubed.
Experienced hands are welcome to help as I've never done a fork job before. Food for labor gladly offered :essen_024:
:feedback:
Some one mention food, ans SNOW cones?
I have not had to do my forks yet. My seals are good and everything is tight so I only intent to replace the springs and oil.
From what I have read, you want OEM seals, after market do not hold up.
Oil weight is a lot of personal preference in how you want the bike to ride, how much weight you carry, etc.
Me 180# Don't think weight in saddlebags & trunk matter. I'm thinking Mobil 1 Syn. ATF (Dextron3) for fork oil, (equal to about an 11 weight fork oil). My goal is a firm but not teeth rattling either.
My oil seals don't leak but while i'm in there.... My dust seals (aka guide boot) are cracked though.
Looking at this micro fiche, I think I need to order numbers, 6, 7, 9, 10, 11, 15, 19 to do a fork rebuild. Not really sure I need all that, or maybe I'm missing something that I'll need.
I wish I remembered for sure but I think I used 10 weight. I know that I used synthetic fork oil and think it was 10 weight. I look tomorrow and see if I still have a bottle of it in the garage. I know that I used no air at all after changing them.
Don, when you did the 99 did you do the bushings too? did they have much wear? What was the mileage on the bike? I need to order the fork parts soon. None of the threads I've read said anything about doing the bushings so I 'm thinking it is not common for them to go bad.
Here is my parts list, anyone see missing parts or un-needed parts for the fork redo ?
. .Gasket, Drain Plug
Yamaha
item: 3MA-23163-10-00
  • Old Sku: 3MA-23129-10-00
$4.72
. .Metal, Slide 1
Yamaha
item: 4NK-23125-00-00
$16.74
. .Metal, Slide 2
Yamaha
item: 4NK-23135-00-00
$10.88
. .Seal, Dust
Yamaha
item: 4NK-23144-00-00
$18.00
. .Oil Seal
Yamaha
item: 4NK-23145-00-00
$18.60
. .Washer, Oil Seal
Yamaha
item: 4NK-23146-00-00
$5.96
. .O-Ring
Yamaha
item: 4NK-23147-00-00
$1.90
