james 1956 Posted March 25, 2015 #1 Posted March 25, 2015 2004 venture Clutch lever frozen after disk replacement
Yammy 08 Posted March 25, 2015 #3 Posted March 25, 2015 I just did my clutch the clutch rod came out a bit while i was oiling disks and cleaning old gasket off.took it back apart pushed clutch rod back in and was fine.
V7Goose Posted March 26, 2015 #4 Posted March 26, 2015 This happens if you do not get the pressure plate properly seated in the teeth of the clutch basket. Goose
james 1956 Posted March 28, 2015 Author #5 Posted March 28, 2015 Thanks the pressure plate wasen't allined. I rebuile the master and slave cylinder but am having trouble bleeding it. The clutch lever doesen't put out much fluid?
