I need some advice. Although my starter on my 93 does not make any noise it seems to disengage rather quickly. I have removed the flywheel, starter clutch and gear. There are no cracks and the 3 parts of the clutch look okay, but the 3 bolts were all loose. Could this be my problem?
It could be.
Those 3 bolts are supposed to be red loctite AND staked to keep them tight.
If they came loose the holes may have become slightly enlarged but not enough to show visible cracking yet.
Simply tightening them will not keep them in. You may have to get new bolts so that you can install them with red loctite and stake them in. Be sure to give the loctite at least 24 hours to reach full strength. It certainly is wort the cheap try.
If you have to replace anything more than just the screws and the gasket, I would contact Dano to get the upgraded starter clutch.
