Morev4 Posted March 6, 2015 #1 Posted March 6, 2015 (edited) Okay before I dig in what should I look for on a slow reacting Tachometer on my 83? Only happens when it's down below 50 degrees and reads but only so far up. I can rev it up from 1200 to 4000 and it will go up slow and stop around 3000 max. When it's warm it works fine, as far as I can tell. I'm thinking the gear inside the instrument cluster is sticking. Edited March 6, 2015 by Morev4
MiCarl Posted March 6, 2015 #2 Posted March 6, 2015 I had that with my speedometer. The bearings that support the needle needed cleaning and lubricating. It's a delicate job, like working on a mechanical watch. I believe I did mine with a 30 year old can of Radio Shack color TV tuner cleaner/lubricant. Mine is gone and I don't think you can get it new. I was using it to clean/lubricate a clock too and after I ran out the clock eventually quit. My wife got me clock oil for Christmas and the clock is back in service. I'd guess clock oil or another light oil (sewing machine?) would be a good choice.
Morev4 Posted March 6, 2015 Author #3 Posted March 6, 2015 okay thanks a bunch, I'll see if I can get rid of the sticking minutes button also at that time.
Venturous Randy Posted March 6, 2015 #4 Posted March 6, 2015 I was thinking something light like sewing machine oil. DO NOT use a cleaner like brake cleaner as if you get any on the face, it will mess the numbers up. Randy
Midicat Posted March 7, 2015 #5 Posted March 7, 2015 And don't let the 2nd Gen guys try to convince you that it revs slowly because it's a 1st Gen. That's just jealousy talking. :stirthepot:
Flyinfool Posted March 7, 2015 #6 Posted March 7, 2015 And don't let the 2nd Gen guys try to convince you that it revs slowly because it's a 1st Gen. That's just jealousy talking. :stirthepot: Besides the 2nd gen guys dont know what a tach is........
iphlue Posted December 1, 2015 #7 Posted December 1, 2015 Confirms my suspicions. My tach suddenly is very slow to the point of sticking. It's pretty cold out as well. Worked just fine last week. Oh joy! Another thing to fix. :-\
