I used to get that a lot when I had my Venture and my Royal Star Tour Classic. Normally it was worse after a hard run home on the super slab, it is the carbs, try turning the petcock off as you approach home to start draining the bowls, then once it is parked, let it idle until it dies because it starved for fuel, that should get rid of the fuel odor.
think I found the problem pulled the tank to check the air box found that all 4 boots to the carbs were just sitting on top of the carbs reset every think will see next week got to go get oil and filter to finish maintenance
