Hey all,
So I got to the point of putting my engine halves back together, I look at #2 cylinders connecting rod bearings to the crankshaft and notice one of them is worn into the copper colored metal.
I would like to replace it, but I can't seem to figure out how to determine what I need.
On the end of the crankshaft are these numbers:
3 3 3 3 3 4
I don't see any markings on the sides of the connecting rods near the caps.
On the bearing that presses into the connecting rod I see this:
D3B
On the bearing that presses into the cap to the connecting rod, I see this:
D3B
Can anyone help me figure out what i should order? What COLOR should I get?
The markings on the rods are not 'stamped' into metal, They are in black ink.
Rod numbers should be 4 through 7, corresponding crank journal numbers will be 0 through 3.
Picture of a 1200 rod showing marking. This one is a number 7.
Gary
Thanks Prairiehammer, but the problem is I can't see a number on the connecting rod. I have the numbers on the end of the crankshaft as I mentioned above.
Maybe I should do the plastigage test and see if its still in limits.. Although I would think that if I can see the copper colored metal of the bearing, the safest thing would be to replace it.
Does anyone know the thickness of the bearings? If I knew that, I believe I could figure my issue out.
