Chaharly Posted January 28, 2015 #1 Posted January 28, 2015 Spent all night tonight working on the brackets for the broken windshield tabs. Kind of had to fight it to get it back together. The verdict.... the windshield sets to high, there is a gap between the fairing and the windshield and also a gap between the chrome trim and the wind shield. I really dont care if the corners of my shield jiggle so I'm probably just gonna take the brackets off. Easiest way to do it.
Eck Posted January 28, 2015 #2 Posted January 28, 2015 Well bud, if I was closer I would help you fix it. I fixed mine using perforated strap used for hanging pipe. it worked like a charm..no gaps when finished. I had to place a piece in the vise and twist it to make it work. The perforated holes lined right up after cutting it to the length I needed. No need to drill/open the holes either. Did same for both sides and never ever had another issue with it.
Chaharly Posted January 28, 2015 Author #3 Posted January 28, 2015 Well bud, if I was closer I would help you fix it. I fixed mine using perforated strap used for hanging pipe. it worked like a charm..no gaps when finished. I had to place a piece in the vise and twist it to make it work. The perforated holes lined right up after cutting it to the length I needed. No need to drill/open the holes either. Did same for both sides and never ever had another issue with it. Itll be a simple fix just hate doing things over lol
SilvrT Posted January 28, 2015 #4 Posted January 28, 2015 Itll be a simple fix just hate doing things over lol If at first you don't succeed, keep on sucking .... errrr trying I mean!
MikeWa Posted January 28, 2015 #5 Posted January 28, 2015 Well bud, if I was closer I would help you fix it. I fixed mine using perforated strap used for hanging pipe. it worked like a charm..no gaps when finished. I had to place a piece in the vise and twist it to make it work. The perforated holes lined right up after cutting it to the length I needed. No need to drill/open the holes either. Did same for both sides and never ever had another issue with it. Can you add some info to this. My new-used bike came to me with the windshield stay end tabs broken and it has been bugging me. Mike
djh3 Posted January 29, 2015 #6 Posted January 29, 2015 Some pics might helps us in seeing what going on and maybe get an idea or 2.
Edbo Posted January 29, 2015 #7 Posted January 29, 2015 Spent all night tonight working on the brackets for the broken windshield tabs. Kind of had to fight it to get it back together. The verdict.... the windshield sets to high, there is a gap between the fairing and the windshield and also a gap between the chrome trim and the wind shield. I really dont care if the corners of my shield jiggle so I'm probably just gonna take the brackets off. Easiest way to do it. Are you talking about the gap on the sides that overhangs the fairing? I don't remember any tabs on windshield broken??? Are you talking about the tabs on the bike?
