fixit3546 Posted January 19, 2015 Share #1 Posted January 19, 2015 I have seen in the past on this site, someones instructions to remove the tape deck and add a jack for an MP3 player. I haven't found it, any help would be appreciated......Thanks! Link to comment Share on other sites More sharing options...
Rick Haywood Posted January 19, 2015 Share #2 Posted January 19, 2015 Tere is no need to remove the tape deck there is already a jack right next to the player when you open the cover. Most guys split the fairing and add a "Y" to the jack and then run the cable to the MP3 player wherever it is mounted. Plays through the AUX on the control box Link to comment Share on other sites More sharing options...
frankd Posted January 19, 2015 Share #3 Posted January 19, 2015 The reason you probably couldn't find it was that I did mine for an IPOD, but it'd work just fine with an MP3 player. http://www.venturerider.org/forum/radio-cb-gps-etc-/44070-tape-deck.html?highlight=frankd+ipod The treble response is a bit hot with this system, so I just set the equalization on my IPOD for "small speakers" (treble cut, bass boost), but if your MP3 doesn't have this function, you could just put a small capacitor across each input to the amplifier. You'd have test different values of capacitors to determine the correct value. Rick, I think this is for a 1st Gen., so there is no OEM jack! Frank---KA9J Link to comment Share on other sites More sharing options...
utadventure Posted January 19, 2015 Share #4 Posted January 19, 2015 I replaced the tape deck with an MP3 port years ago. Used a piece of abs plastic to replace the missing take deck. Remove the deck and unplug it from the cable going to the audio system. I bought an matching 8 pin din plug from a local electronics part store. In the abs plastic, I installed a switch and a female 3.5mm stereo jack. Wire the switch to pins 1 and 7. On will override the am/fm as though the cassette player was on. Wire the stereo plug to pins 3,4, and 5 (i belive 4 is the ground pin, with 3 and 5 being he left and right channels) Not really very hard and easy to remove and install. If you plug into the port and play music, it will sometimes override the radio without throwing the switch. Good luck!! Link to comment Share on other sites More sharing options...
fixit3546 Posted January 20, 2015 Author Share #5 Posted January 20, 2015 I think that is what i was looking for utadenture,....Thanks frankd and Rick for your input. Link to comment Share on other sites More sharing options...
