I have a 2012 RSV, and I'm having a problem with the passing lights. The right side will go off and come back on at random times going down the road. Has anyone experienced this problem? Both bulbs are new and still do the same thing.
Thanks for any help.
It could be a poor ground connection, a poor power connection under the fairing or a bad bulb. It will help you a lot if you can make it flicker by tapping on it.
Mike
Look in the piviot point of the forks. The passing light "bundle" of wires is there. Sometimes they will get pin vh1 ed or a bullit connector comes loose. But definatly sounds like a ground problem.
While you are looking at the pivot point for the forks check for any chaffed or pinched wire. It is common for wires to get pinched by the steering stops on both sides.
Something you may want to think about is if it's hooked up from the factory, it's not the best configuration. I have always run a dedicated wire through a relay to power the passing lights. There are several threads in the forum on doing this. I do agree with others that a bad ground could be your culprit.
I had the same problem. If the light were not installed properly the wire going to the bulb socket can get pinchd and eventually breeak. On my other sidr, the ground wire inside the light housing seperated. I had to resolder it to the housing. Be careful you don't get the housing too hot because I think it could blue up the chrome.
Inside the light, if its a h-3 halogen bulb there is a ground wire that screws to the housing back. Mine does not allways make a good contact, and last time I had it appart I had to add a washer to make it get good contact.
