Trader Posted December 12, 2014 #1 Posted December 12, 2014 OK...now I have your attention I should mention that I am not afraid nor looking for someone to be brave. What I need is a single ball bearing steel ball. I have a "princess auto", air and hydraulic bike table lift with a release pedal. probably made in China The pedal pulls a pin on bottom of the hydraulic bottle which allows a steel ball to open a port, releasing the pressure and allowing the oil to flow thru an outlet port back into the reservoir. I lost that steel ball and you wouldn't believe the problems I have been having trying to find a replacement. Princess Auto themselves were no help....and the manual doesn't specify the size. or where you can order parts One company would only sell me a bag of 100 for $12.95 It is deep inside the base but as near as I can eyeball it with my micrometer it is 0.141" or 3.62 mm. Closest match is 1/8" which is .125" or 3.19 mm If anyone has one single ball bearing or a few different ones around that size and would be willing to throw it in an envelope and mail it to me I would appreciate it!!!!! The lift is useless without it. The shaft that pushes the ball bearing into the port to plug the pressure has a bad o'ring...so it leaks like a sieve. That's why I pulled it apart. That shaft is Spring loaded...I never even saw the ball bearing go flying out.
ReinyRooster Posted December 12, 2014 #2 Posted December 12, 2014 Sorry trader....I have no balls.....
Flyinfool Posted December 12, 2014 #3 Posted December 12, 2014 I have balls of steel but they are a lot bigger than what you need. I have a whole bag at .750 dia.
SilvrT Posted December 12, 2014 #4 Posted December 12, 2014 If I jump into a cold tub of water, I might be able to help you out .....
wannarsv Posted December 12, 2014 #5 Posted December 12, 2014 I just checked I have some balls of steel 1/2" & 7/16". I almost forgot I had balls of steel till I read this post. But then I remembered a long time ago I need steel balls. so I got some. If you think My steel balls are what you need, then let me know I will put my steel balls in an envelope and mail them to you, Then you too my friend will have balls of steel. Melvin
Flyinfool Posted December 12, 2014 #6 Posted December 12, 2014 You can get your steel balls here. McMaster-Carr They are 9/64 Dia or .1406 Dia. Yes you will get a bag of 100, but it is only $3.75. AND you will be able to say forevermore that you to have balls of steel in your bag.
Prairiehammer Posted December 12, 2014 #7 Posted December 12, 2014 ... in your bag. Unless Trader is monochismastic, shouldn't the phrase be plural? I.E. 'bags'
SilvrT Posted December 12, 2014 #8 Posted December 12, 2014 Unless Trader is monochismastic, shouldn't the phrase be plural? I.E. 'bags' Then he'd have to buy TWO BAGS of BALLS .... or, get them shipped 50 to a bag
Trader Posted December 13, 2014 Author #9 Posted December 13, 2014 I just checked I have some balls of steel 1/2" & 7/16". I almost forgot I had balls of steel till I read this post. But then I remembered a long time ago I need steel balls. so I got some. If you think My steel balls are what you need, then let me know I will put my steel balls in an envelope and mail them to you, Then you too my friend will have balls of steel. Melvin thanks...but way larger than I need
djh3 Posted December 13, 2014 #10 Posted December 13, 2014 There is just way way to many openings for sly n funny comments here. I'll check back later, because I just know ole Puc is thinkin sumtin up.
Marcarl Posted December 13, 2014 #11 Posted December 13, 2014 I keep what ever balls I find, you just never know when a feller might need them. So I measured some that I have that come from England I believe .125 or.157,,, interested?
BIG TOM Posted December 13, 2014 #12 Posted December 13, 2014 I know a lot of guys with balls, But you would have to talk to their wives if you want them because they keep them in their purses for them.....
ricksbike Posted December 13, 2014 #13 Posted December 13, 2014 My local Ace hardware store has a lot of little balls.
cowpuc Posted December 14, 2014 #14 Posted December 14, 2014 There is just way way to many openings for sly n funny comments here. I'll check back later, because I just know ole Puc is thinkin sumtin up. Heyyy,,, leave me out of it DJ,,, I aint teasing noooo body having those kinda problems,,, even I gotta draw the line somewhere!!!!
Jayceesfolly Posted December 14, 2014 #15 Posted December 14, 2014 Hi Steve: If you have an old Zerk fitting, check out the ball in the tip. Not sure what the size it is but may work. Pull one off an old piece of equipment and cut the tip off with a hacksaw. Just thinking out loud here. Jim
cowpuc Posted December 14, 2014 #16 Posted December 14, 2014 OK...now I have your attention I should mention that I am not afraid nor looking for someone to be brave. What I need is a single ball bearing steel ball. I have a "princess auto", air and hydraulic bike table lift with a release pedal. probably made in China The pedal pulls a pin on bottom of the hydraulic bottle which allows a steel ball to open a port, releasing the pressure and allowing the oil to flow thru an outlet port back into the reservoir. I lost that steel ball and you wouldn't believe the problems I have been having trying to find a replacement. Princess Auto themselves were no help....and the manual doesn't specify the size. or where you can order parts One company would only sell me a bag of 100 for $12.95 It is deep inside the base but as near as I can eyeball it with my micrometer it is 0.141" or 3.62 mm. Closest match is 1/8" which is .125" or 3.19 mm If anyone has one single ball bearing or a few different ones around that size and would be willing to throw it in an envelope and mail it to me I would appreciate it!!!!! The lift is useless without it. The shaft that pushes the ball bearing into the port to plug the pressure has a bad o'ring...so it leaks like a sieve. That's why I pulled it apart. That shaft is Spring loaded...I never even saw the ball bearing go flying out. Trader,, you get this figured out?? Any idea what size of an o-ring you might need to go with that bearing? I will dig around a little and see what I can come up with...
cowpuc Posted December 14, 2014 #17 Posted December 14, 2014 Ok,, did a little digging,, I had cabinets of those small parts that went out when I sold my air gun stuff,, bummer.. A little research down in the man cave did bring about a couple observations.. If the little ball is being sealing against an o-ring would a precision "BB" maybe work? I have those left over in both .177 and .22 - these are BB's for shooting in a BB gun though - if its sealing against a metal orfice you will probably need a precision bearing.. Also,, if you look at the female portion of a quick disconnect for an air hose (2.50 at HARBOR FREIGHT pictured below) you will notice that the ball bearings that serve as the internal disconnectors are 1/8th inch (I measured em a minute ago with a scale - might be off a few thou).. If you have an extra one of these disconnects laying around, there is little snap ring at the end where the male end plugs in that holds it together - get cha 3 x 1/8th inch bearings... http://www.harborfreight.com/media/catalog/product/cache/1/small_image/135x/9df78eab33525d08d6e5fb8d27136e95/i/m/image_13967.jpg
Trader Posted December 14, 2014 Author #18 Posted December 14, 2014 Thanks for the idea Puc. Marcarl may have some for me but if they don't work I'll destroy an air fitting ans see what I can come up with. Someone else suggested BBs and gave me some (.177") but I haven't tried them yet. The O-ring is not a problem. A friend gave me a kit with lots off different sizes.
Marcarl Posted December 15, 2014 #19 Posted December 15, 2014 Hi Steve: If you have an old Zerk fitting, check out the ball in the tip. Not sure what the size it is but may work. Pull one off an old piece of equipment and cut the tip off with a hacksaw. Just thinking out loud here. Jim Good idea Jim,,,, but those thingies are spring loaded, so when he gets the end cut off he'll have to find 2 lost bearings...... lol
Flyinfool Posted December 15, 2014 #20 Posted December 15, 2014 By the time you get done destroying things to find your balls of steel in the perfect size, you could just order the right size from McMaster and be done with it and save both time and money. AND still have balls of steel for another day. I have many bags of stuff hanging around the shop from buying 100 of something and need 1 or 2.
