azxvz1284 Posted December 9, 2014 #1 Posted December 9, 2014 Has anyone used an aftermarket radiator fan that is more efficient; flows more air, etc? Any recommendations? Thanks, Richard in AZ 1988 VR
Prairiehammer Posted December 10, 2014 #3 Posted December 10, 2014 azxvz1284 said: Has anyone used an aftermarket radiator fan that is more efficient; flows more air, etc? Any recommendations? Thanks, Richard in AZ 1988 VR Muzzys used to sell an aluminum fan blade for the Ventures (and the same fan for the V-Max), but a check of their website indicates that the aluminum fan blades are backordered. If you do a search for Muzzys fan blades for First Gen Ventures and V-Maxes, you may find something still in stock somewhere. The Muzzys part number for the Venture/V-Max fan blade is HT-H5. Muzzy Aluminum Fans
Flyinfool Posted December 10, 2014 #4 Posted December 10, 2014 The Muzzy fan looks like it might flow more air when it is running, but it also looks like it will block more air when it is not running. Meaning the fan will need to run more often and/or longer. I guess the real question is why do you need a better fan? The stock fan cools things down pretty quick even in 100+ heat. If it is electrical load that you are trying to reduce, then you need a more efficient motor, not a different fan blade. A fan blade that moves more air will also pull more amps, more amps could cook the fan motor.
videoarizona Posted December 10, 2014 #5 Posted December 10, 2014 Richard, I agree with Jeff. I've had no problems with my 89 1st gen in heat. Fan kicks in near top of green on temp gauge and keeps the engine at that temp. Even idling in heat. If you are having overheating issues...suggest you completely go over the cooling system...from radiator flow to thermostadt. make sure the system is flowing properly would be my first guess....Also make sure the coolant temp sensor and the fan sensor (both on lower right side) are clean. david
azxvz1284 Posted December 11, 2014 Author #6 Posted December 11, 2014 No overheating observed, just thinking ahead to the 110 summer temps and remembering my vr12 experiences. Thanks, guys. videoarizona said: Richard, I agree with Jeff. I've had no problems with my 89 1st gen in heat. Fan kicks in near top of green on temp gauge and keeps the engine at that temp. Even idling in heat. If you are having overheating issues...suggest you completely go over the cooling system...from radiator flow to thermostadt. make sure the system is flowing properly would be my first guess....Also make sure the coolant temp sensor and the fan sensor (both on lower right side) are clean. david
videoarizona Posted December 12, 2014 #7 Posted December 12, 2014 azxvz1284 said: No overheating observed, just thinking ahead to the 110 summer temps and remembering my vr12 experiences. Thanks, guys. Crossing fingers you don't have the same problems. I don't on my 89....but that was this past summer! Grins... david
tucson_sailors Posted December 13, 2014 #8 Posted December 13, 2014 videoarizona said: Crossing fingers you don't have the same problems. I don't on my 89....but that was this past summer! Grins... david well, I'll let you know how the "poor mans fix" of a lower kick on temp sensor for the cooling fan works. My new to me 87 doesn't appear to have a working fan sensor and temp gauge sender, so in prep for this weekends cooling system flush (new coolant, thermostat, etc) I also got a lower temp auto (88 chevy sprint) temp sensor for the fan. Think the thread is on poor mans or 1st gen in this forum. It's supposed to kick in at 180, rather than the stock (194?) which would mean more off/on cycles, but with 115 as a regular temp down here in the summer, I'm willing to live with. Leaving the factory temp thermostat for now, but that would be the next idea if it runs hot. I'll see about putting that in if after pulling and cleaning the wiring and using some dielectric grease doesn't fix my "not hearing it running" fan issue with the current installed ones. I had them turn on once on the ride home, but test rides in similar situations have not, and without a working temp gauge I'm really leery of overheating. No desire to turn my new baby into a heart transplant candidate. Have done the "pull and squeeze" on the temp gauge single wire, but not working, and not sure if sender bad, gauge burned out, etc. I may simply plumb in a real capiliary tube style temp gauge - have an inate distrust of idiot lights and electric gauges where temp and oil pressure are concerned. Glenn in Tucson 87 VR 1300 Motortrike conversion
