JDaniel Posted December 8, 2014 Posted December 8, 2014 Heated seats and grips are not working on 07 Goldwing. Fuses are good. What should I check next. Waiting on a repair manual for the bike.
bull463 Posted December 13, 2014 Posted December 13, 2014 I would check for power where it goes into the seat also power going out of the switch Bull463
JDaniel Posted January 3, 2015 Author Posted January 3, 2015 Did some research on the internet. Tested each unit individually. Rear seat heater works. Drivers seat heater works. When you turn on the grip heaters it shuts down the system. It usually is the left hand grip which goes bad due to the stress on that grip when putting the bike on the center stand. Will have to look for a new grip or aftermarket heated grips.
YamahaParExcellence Posted April 14, 2018 Posted April 14, 2018 Heated seats and grips are not working on 07 Goldwing. Fuses are good. What should I check next. Waiting on a repair manual for the bike. I'll bet you anything that it is the ribbon connector. They get pulled on and stressed, when you put your Wing onto the center stand, or off..or you torque on the grips for ANY reason. Nine out of ten times, it is a broken or severed wire in that ribbon..and the only thing that can be done,...is a new grip. Ask me how I know..., and one more thing...so retarded how Honda this in the wiring harness...but the entire heating system...grips, seat(s) are serial wired, like old Christmas and Christmas tree lights. If any of the grips stop working...bad wire, stressed/pulled wire/severed wire, NOTHING that heats will work. One of your grips goes south...and you don't use them much anyway..but you use the heated saddle? Too bad...it's all dead, until you find the part that has failed, and replaced it with new. A very bad design, that is in all Goldwings with heated grips and seats.
mralex714 Posted April 14, 2018 Posted April 14, 2018 I would check the connector in front of the ignition switch under the panel you take off to get to the speakers.
